Hello all -
Congo v6.0.1 is now available for download from the Congo page here. It is highly recommended that you update to v6.0.1 as soon as your production schedule allows as it addresses a number of issues discovered in the field. Please check the release note for a listing of what has been fixed in this version. Also, if you use the RFR in At Mode, a bug was discovered last week that you should know about - using the [.] key on the RFR to conclude a channel selection command can cause a crash. Please use the [@] key instead.
Thank you for your patience and please as always let us know if you find anything else of concern by sending us comments at congo AT etcconnect.DOT com.
Thanks -
Sarah
