Hi All
There is a question about a version 6.
What kind of function is "Active parameter lock" of a Master setting?
Moreover, a flash button cannot be used when a palette is assigned to a master. What does it activate?
Best regards,
Kani
Hi All
Best regards,
Kani
Active Parameter Lock: Parameters controlled by the master will be protected against other changes when the master is active. This is a way to lock out changes to the parameters from other masters or sequences.
The Flash button doesn't activate anything in palette mode since there are no intensities to flash in this case.
Hi
Active Parameter lock: For what kind of case is this used?
When using this function, it becomes impossible to use the flash button of Master which always assigned Pallette.
The flash button of Palette can be used at the time of starting of a console.
It cannot be used from the time of On(ing) this "Active Parameter lock".
Even if it Off(s) this, it cannot be used.
I regard this as strange.
Kani
