congo jr.
Hi
I have a problem with congo jr. .How can i use together masters and direct select  at the left side on fader wing.If i had master on with content moving lights and i want too change gobo or color or position and at the same time i want bring on some other master the thing does not work.
THX  Miha
  • Hi Miha -
    You cannot use the direct select mode and master mode simultaneously on a Congo jr Master Playback Wing. You have a couple of different options, though.
    1) Use the direct selects on the Congo jr console LCD.
    2) Assign the palette(s) or group(s) you want to select directly to masters as well.
    I hope this helps -
    Thanks -
    Sarah
