Hi. It is possible to change the time of working berofe RFR transmitter go to stendby?
Hi Michal,
yes - you can change the Standby Time for the Display of the RFR Handheld.
Press the "C" Key when turning on the RFR, and then you will be able to set the
HF Channel. If you press the softkey then NEXT a couple times, you come
to the backlight off time. You can set this from 10 seconds to 30 minutes.
Have fun!
Hi Corey. Thanks.
