Patch not refreshing
We're having frequent problems with the patch not refreshing.  About 10% of the time the display will not show the new info for a second or two.  Sometimes it will show up when you arrow to the next field, other times you have to retype the info to get it to show up.  Occasionally the info will show up but the lamp won't respond when you bring the channel up.  Closing the patch window usually helps but sometimes we have to reopen it and type the new info again.
Could this problem be related to "RND 0001903 Changing patch data with multiple patch views open does not refresh data in those other tabs.
We are running both a client and a file server on the network.  We notice these problems more often when patching from the client but I suspect that is only because we do more single channel patching from the client than the console.  We use the client as a remote during focus calls and as a designer display during tech rehearsals.  The initial patch is generated from Lightwright 4 and corrected through a series of find and replace commands in MS Word to make the ASCII file compatible with Congo.
We are on version 6.0.3.
Mat
Parents Reply Children
No Data
