Template for a Martin MAC401 ( Dual)
Has anyone tried to write a template for a MAC401 ( Dual), with all his ranges?
Please let me know, I do have a show this week-end, and this could save me a lot of work.
  • I'll take a look at building you the RGBX - All mode (default mode).
  • Ok - attached is a Congo v6 showfile with several Templates for the Mac401.
    The RGBX, RGB, HSX and HSV versions are designed for use with "PGRP" set to "ALL"
    If you want to divide the fixture into segments, the above templates will control only the first segment.
    I'm not sure about the best way to control this fixture in the 2 or four segment PGRP modes.
    -It may be best to delete the last four attributes from the 'main' template and patch all of the two/four segments as separate channels.
    "Mac401 RGB Segment" and "Mac401 HS Segment" can be patched directly after the main fixture to give control over the other segments in the two colour mixing modes.
    - Note that I haven't tested this on a real fixture, so I'd appreciate it if you could let us know any suggestions for improvements.
    Edit: Mac401 Segment HS shouldn't fade Hue and Sat with intensity.
    [edited by: Richard at 9:07 AM (GMT -6) on Fri, Feb 26 2010]
    mac401 dual2.asc
