I can get the Mac 700's to respond to the color pickers, but not the CXI's. I am running 6.0.3 Sr. The CXI's are in three channel mode. How can I get the CXI's to respond to the color picker?
The Color Picker and Gel Picker works on devices with separate CMY parameters. Unfortunately, the CXI uses a combination of two DMX values for its color mixing and therefore cannot be controlled from the Color Picker (or Gel Picker).
Will this setback be changing with the implementation of the EOS color picker later this year??
Hi Jeff -
I will look into it. I cannot promise that it will, though. It's quite complicated.
Thanks much -
Sarah
