Should it be possible to create direct selects using the Congo offline editor and should the encoders work as well (at the moment I dont get any values on them)?
Orri
Orri
Hi Orri -
I have no problem setting direct selects nor with using the encoders. To set direct select contents in the Console Mimic dock, press CTRL & click the Type button on screen, then click the direct select button that corresponds to the type of data you wan t to place on those keys. To use the encoders, click on the encoder and drag to move it up or down.
I hope this helps -
Thanks -
Sarah
Brillitant thanks. Didn´t know about CTRL for the direct selects and patching error regarding the encoders.
Regards,
Orri
