Loading sequence to main playback
Can a step being played in the main playback (say the last step in a sequence) load new sequence to the main playback (on B)?
Orri
  • Hi Orri -
    I think you are looking for the Play List function, where you can build a stack of sequences to be played back in order. Play List is a mode softkey in the Misc. soft key menu. You can open the Play List editor tab either by pressing and holding MODIFY and pressing the Play List softkey, or directly in the Browser in the Main Show Data section.
    I hope this helps.
    Thanks -
    Sarah
