Seq - & +
Hi all when I Go back and forward using the seq - + to view my Presets some Dynamics load automatically. Why is this ???
Is there a way of going back and forward in presets with out Dyn starting, Is the only way ? Goto.
Carl
[edited by: cknapper at 11:26 AM (GMT -6) on Thu, Nov 30 2006]
  • Hi Carl -
     Whenever you use the SEQ +/- Button it will step sequentially thru your sequence within the main playback without timing.  It will still play all your dynamic effects.
    It does this because dynamics are playing within the playing preset.  Dynamics will always activate when ever a preset is playing; weather it's originated from the main playback, or a master playback.
    I do agree that in some instances it would be advantageous to possibly have a soft key within the dynamics window to disable dynamics when stepping thru the SEQ +/-.
