start macros in sequence
How use the macro's column in the sequence ?
Sometimes I need play an other sequence on a master, if I want to do GO or goto x in this other sequence...
thanks.
[edited by: pilou at 6:04 AM (GMT -6) on Mon, Aug 27 2007]
  • You can use the Macro column, in which case you simply enter the number of the Macro you wish to happen when the sequence step occurs.
    Macros can be recorded via the [Misc], # [Learn Macro] softkeys - after hitting all the keys you want in the macro, click on the "Recording Macro" text on the top right of the screen. You will need a mouse on Congo Jr. (The reason for this is to allow you to record all keypresses - mouse moves aren't recorded)
    [edited by: Richard at 4:00 AM (GMT -6) on Tue, Aug 28 2007]
