Auto save(Congo)
Hi
I Like too know what hapend if auto save is off can i lost the exsisting file or somthing else
  • Hi Miha -
    I am not sure what you are asking...
    Normally Congo has auto-save off as it performs a save after every time you use RECORD. It is always recommended that you save your play to the hard disk on the Congo (Browser>Files>Save As>Play Archive...) and to an external drive, such as a USB memory stick.
    This way you will be sure not to lose data.
    Thanks-
    Sarah
  • Hi,
    The method i use is.
    after first saving my new show you can use C/Alt and Update to make an iterative save so you build up a history and don't have to go into the browser.
    Just for info C/Alt and Record creates a new show file in the Show Archive.
    Hope this helps remember if you've done something you don't want to repeat C/alt and Update.
    Cheers
    Jeremy
