Is it possible to set levels from the in the Output Editor, grid view, from the client? The syntax on the console, # Output # Level, doesn't seem to work on the client.
Hi Mat,
Currently, we have a limitation when setting output levels from a client. I am not sure when this limitation will be removed.
