Hi all,
If you want to do some busking I came up with this trick.
- Select the devices you would like to have a Dyn.
- Mask ALL attribute
- Rec. to master
Now you can use this Dyn. on those lights whenever or whereever you like. And the fader becomes Size and Rate or either one.
Since there is no attribute recorded the Dyn. will apply on top of your "look".
Bullen
[edited by: Bullen at 3:43 AM (GMT -6) on Sun, Dec 03 2006]
