Tracking attribute values through presets
Is it possible to track attributes through presets either as an absolute value or as a palette through presets other than using Update & Attribute?  Say if i want a new focus position or colour to track through regardless if it changes in different presets (which would stop normal tracking).
Orri
  • As you want to erase some existing moves this isn't a tracking edit, so you have to use a different kind of editing.
    You can do this in the Track List as follows:
    Select channels, [Track], then [Format] & [Attribute_Key] to toggle the display of the appropriate attributes to the track list.
    - Eg [Format] & [Focus] to show all the Focus attributes.
    You can then use the usual spreadsheet editing tools ( [Select] & [Arrow_keys] etc) to put changes into many Presets at once.
    You can also use # [Record] & [Ch/Id] to store the intensity and attributes of the currently-selected channel(s) to Preset #.
