The browser setup on Congo JR (version 6.04) does not hold if the desk is turn off and then on ie if Effect, Selected Live etc have been opened on either of the two monitors.
Can this be added to the info saved with each show file?
Orri
Orri
Hi Orri -
This is fixed in v6.1, but you can fake it in v6.0.4 by doing the following:
Open your show and set up docks and tabs the way you want the show to start up next time.
Exit Congo. You do not need to save the show at this point.
Relaunch Congo from the welcome screen. Choose to use the data from the last shutdown. You should see your show file with all the docks and tabs as they were when you exited Congo.
Use SAVE AS to save over the original show file. This should reset the default screen layout for your show file and keep things consistent. Please note, if you change the screen layout with new docks or tabs, you will need to repeat this if you want that layout to appear when you open the play from the Browser and not with "use data from last shut down".
Again, we have changed this behavior in v6.1 so that the show file will always store the screens as well when you use SAVE or SAVE AS. :-)
Thanks much -
Sarah
