Currently when the Playlist is active it will continue advancing the sequences in the original order even if the operator breaks out of the sequence list order.
For instance: Playlist active and sequence 1-3 run its course. Sequence 6 loaded and run its course but then sequence 4 is loaded next, not sequence 7.
Stopping the Playlist and activating it again does not stop this logic.
Also, can the Playlist be activated for a sequence that is loaded on a Master?
Orri
