hello,
we've just updated to 6.0.4 and it seems that when we turn on the desk, startup screen is bypassed, even though the option is unchecked in the settings tab.
anyone has a clue?
thanks
Stephan
hello,
anyone has a clue?
thanks
Stephan
There are two settings that bypass the startup screen: "Bypass Startup screen" and "Load Specific Play".
If you've got Load Play set to anything other than "None", it will also bypass the startup screen.
- In v6.1.0 we're merging the two into a single setting to make it clearer.
As some people surely tell you very often : Richard, You're the King !
thanks for your quick answer. we've got it all figured out now.
Stephan
It is not a trick, it is a Congo
Be inspired , by Congo
Enjoy Congo and find the way in new big areas.
Wishes from Gemany.
Thorsten Scholz
Theater an der Ruhr / Mülheim an der Ruhr / Germany
