Master update bug
I have recently updated out console to 6.0.4.
I have tried using [Update] & [Master button] to update the contents of a preset on a master.  The preset gets updated with the selected channels, but the master retains the channels & levels from the previous setting.  The master is usually up, but fading to 0 and back does not update.
Fading to 0% and using [Page+] [Page-] refreshes the master and it gets the correct preset content.
On 5.1 I used to use [Record] & [Master button] which brought up an update dialogue if there was already a preset assigned which updated the master correctly - but 6.0.4 doesn't give that option.
Trevor
  • Hello Trevor -
    There is a known issue regarding the updating of presets on masters and you have discovered the workaround - you can also reassign the preset to the master to force the updated preset to appear. This is fixed in the upcoming v6.1 release, currently in beta testing.
    Thanks for the input.
    Sarah
