Hi there
Is there anybody that can help me? Is there a easy way that you can go between channels to turn them on full instead of typing each number each time you want to move around your rig to foucs?
ta
Patch
Hi there
ta
Patch
Hi -
You can use the HIGHLIGHT function for this - Turn on HIGHLIGHT by pressing the button of the same name - its LED should light and you should see "Highlight" indicated on the screens. Select your first channel, then you can simply use the + or - keys to advance or move backwards from one channel to the next. You can also select a group of channels and use NEXT/LAST to move through that selection only one channel at a time and in selection order.As channels
Be careful - as soon as you select a channel or a group of channels, they will be set to their highlight level for devices or ID level for normal channels - selecting the whole rig while in highlight mode is not recommended as this can stress your dimmer racks/power service/eyes depending on how many channels you have.
As you focus your selection using NEXT/LAST, the other channels will return to their previous levels with only the focused channel remaining at the highlight level.
When you're done focusing your rig, simply press the HIGHLIGHT button again to turn this mode off.
I hope this helps!
Thanks -
Sarah
Hi Sarah
Thanks for that will try it tomo at the theatre when im doing the get in
many thanks
patrick
