At Mode
With version 6.04 is it possible to switch from RPN to @ mode without going via system settings?
Not the end of the world but would be nice if it is still possible without almost powering down the desk.
John
  • I'm afraid not.
    By request it was changed to a global console setting instead of a show setting in v5, which moved it to System Setting along with all the other global console settings.
    One trick here is to turn Freeze on while you're in System Settings (or Welcome Screen), as then the output of the console won't change until you flick the switch back to On.
