I want to ask a Congo user.
Hi All.
Change of each Master Setting was attained by Ver6.
SETUP & Master key.
I change from Master Page, when changing two or more Master Fader Setting.
However, even if it changes the page currently displayed on Master Fader, it is not reflected immediately.
Once, it must move to other pages and must return.
Don't you think that this is troublesome?
Best regards,
Kani
  • Hi Kani -
    Changes made in the Master Page Editor are done blind by design, as with many other editors, requiring you to reload the master page to make those changes take effect.
    You can setup many masters at once using the dialog.
    Press # MASTER # +/THRU to select many masters.
    Then press SETUP & MASTER to open the Master Settings dialog for all selected masters.
    WARNING: In version 6.0.4, this dialog will change all selected masters to those settings upon closing. It is not recommended to use this method if you have many diverse settings on those masters as they will all become the same when you close or escape the dialog. In v6.1, you have the option to leave the dialog without making any changes to the selected masters.
    Thanks much -
    Sarah
