On the the channel layouts is there any way you can make the text bigger and move the text? Iv noticed on the preview for the Congo kid on the web site on the left hand monitor they have text above circles and channels how do you do that??
Hey Patrick,
The trick for putting text on your channel layouts is detailed in the wiki:
Text labels can be created and moved around in layouts by creating a line, assigning Text to it, and then reducing it to the shortest length possible (which effectively makes it a dot). Scale them up to the appropriate size and you've got Text labels you can move around as seen here:. Example
Hi there
Brillant cheers
