in the dropdown box of the editor it offers intensity as the first option. Is this meant to work on the heads you are working with at the time?
Hi Andy,
The user parameter assigments you make to the U1-U3 pages are fixed and global. They are not related to the currently selected devices.Since the normal FCB pages are dynamically following the current selection, the U-pages are designed to keep all parameters in a fixed place and not jumping around.
The editor popup shows all defined parameters, including Intensity which is the first one. However, you cannot really use Intensity on a parameter wheel since it isn't an LTP parameter.
