Is it possible to change the column widths in the main playback?
In 'spreadsheet' type views I can select a column and use COLUMN & WHEEL. In the main playback columns cannot be selected so that can't be used.
I thought so. Increasing the size of the step name area is something my users often ask about. The best I can suggest is to minimise the browser window.
Something for the wish list then:
Allow main playback columns to be resized
or
In the 'minimal' format of main playback, maximise the step name area by making the other column widths fixed.
or
Add a more minimal main playback format that gives most of the space to the step name, with minimal timing info.
