Greetings,
I need a template for the Elation Quad Par... Anyone out there that can help me out? Need ASAP, thanks!!!
-Ethan
Greetings,
-Ethan
Which mode do you want to run this fixture in?
I would suggest using the Generic>RGBW template to get you up and running. (set the Quad Par in 4ch mode)
Graham
Graham,
Thanks for the tip... I am going to use the generic version. Other modes not needed for this gig.
Cheers!
