hello all
Isn't there method of exporting template file ?
I want to take out only not the show file but the template.
best regards
hello all
best regards
There is no concept of Exporting in Congo. Instead, you can use the Import Wizard to import different types of data from another show.
Load the show you want to import data into and use Import Wizard to fetch the data objects you want from any show file.
Thank you Mr. Anders
Ok. I will use import wizard function
