I select a device and open the track list for it. I then select an attribute to edit (say strobe channel via Format & Strobe). I then select a single cell, whole column or selection of cells to edit. If I press 1 modify (in Palette mode) to select beam palette 1 (say shutter open) the selection that is made is All Palette 1. Is there a way to specifcaly select from the beam palettes or Focus palettes instead of the default All Palette?
Orri
