Feature requests
Feature requests
 1. (NP) [out] should set that parameter to 0. For example {red}[out] should be the same as {red}[at][0]
2. Have the ability to save all show/desk/display settings to a file on the USB drive. That way when I come in to a new console, I can just import or merge my file and not have to set anything up. Or when I'm covering someone else I can load my configuration and then set it back to the way he had it.  This has been implemented; thank you
  • "For #8 if you hold down the [Data] key and then select the parameter tiles in the CIA it will hide those parameters."
    No, that hides the parameters in table view.
    ueliriegg
    In reply to saranow:
    i think with #8 he means to get rid of the tiles as such. but wouldn't collapsing the CIA do that?
    You are correct on both counts. So it's not that big a deal. The reason why I posted that is I keep the CIA open all the time because otherwise when it opens (like pressing [effect][effect]) it messes up my layout. Also I keep the About display favorited and always open in the CIA, and sometimes there is too much information to display without scrolling side to side. I work on some shows that are conventionals only, or conventionals with LEDs so having the Focus and Beam categories is just a waste of space in that case. Not to mention the empty column. What is that one for, anyway?
    Edit: This is no longer relevant now that the "about" display can be opened in a frame
  • More/better keyboard hotkeys
    Unused keys that can be used:
    Edit: No longer applicable in version 2.3
  • John, the hotkeys map is being changed as we speak. The challenges are the various international keyboards, the smaller ones (with less than the regular 101 buttons, they often miss F11 and F12) as well as the whole Mac/PC differences...
  • 15. I would like the ability to lock all frames. The way it is now, I have one frame that I shrunk as small as possible, but it doesn't shrink all the way down and it wastes space on one of my monitors.
    16. Keep a spreadsheet visible while switching to live. Keep it as the same spreadsheet instead of reverting back to a spreadsheet of cues.
    17. I would like the ability to edit a spreadsheet in live.
    18. When editing a magic sheet, it should remember the font size, style, and color of the text fields in the MS object properties
    19. When copying elements from one magic sheet to another, the targets should stay the same.
    20. Keep the ability to use "undo" after saving
    21. Keep the command history available after saving
  • 22. Have an option that when on the first cue in the cue list, pressing "stop/back" doesn't black out the entire stage.
    A couple times I hit "stop/back" too many times by accident and made the whole sound stage dark.
    Implemented in 2.4. Thanks!!!!!!
