Fixture Profile Request: Futurelight CC-200
Hi all,
First of all, I would like to wish everyone a merry Christmas!
I need a fixture profile to be created for the Futurelight CC-200 fixture. Unfortunately, I cannot locate a PDF version of the manual anywhere as the manufacturer do not have a website. If anyone can still somehow ascertain the correct data to build such a profile, I would very much appreciate your efforts.
The production I will be using fixtures of this type in will be taking place on 14th January, so ideally I would like to have the profile within the first week of the month to permit sufficient programming time.
I would be very grateful if someone could assist me in this rather short time frame.
Have a happy new year!
Many thanks,
Aaron
  • Hi Sasha,
    I have sent you a message, but I'm not sure if you'll have seen it. Could you update me on the status of the fix?
    I have a technical rehearsal for the show I originally mentioned tomorrow, so really need the file prior to then.
    Thanks.
  • have you tried if the robe fixture profile works?
  • It does work apart from the missing range for frost on the intensity channel and slightly misaligned values on the colour wheel channel.
    I received a library update from Sasha last Friday containing a profile for the CC 200. Unfortunately, it was pretty much a carbon copy of the Robe profile, apart from the addition of one other problem--the effect wheel had three ranges defined for a UV filter where there are actually gobos. I found that bizarre considering both fixtures are essentially the same.
    After being in contact with them for the last week, tonight I have been issued with a new fixture library update. My fixture is a rather odd one due to frost and intensity being combined on to a single channel, however, hopefully they have been able to work around this. I have to yet to test the new personality, however I am informed that the intensity parameter now has control over channel 4 between 0 and 127, and a diffusion parameter has been added to control the same channel but between 193 and 255. Fingers crossed that it all works.
