Will version 1.5 fix this...
While experimenting with 1.4.5 at home (using 1.4.2 in the theater), I've yet to find an answer to this question..If I hit this particular GO button, will my moving light corkscrew to a new focus live onstage?  The annoying thing is..the console knows that answer already, but won't tell you about it or prevent it.  If you have to alter the show sequence at the last moment, this can really be a problem.
What we need a is Black While Moving function (BWM) from a console that doesn't yet have true Move In Black (MIB).  That is, someway to force fade the mover in anticipation of moving to a new mark for the pending cue.
In pursuit of a solution I came across the following limitations as of 1.4.5
1.  Changing sequence by linking to or loading a different cue in the same list results in a GOTO CUE (stateful) style of fade, with no regard to what's moving/tracking in the target cue (this is an option in the hog).  This is bad for my workaround because my anticipation (setup) cue wants to only fade the lights that need to mark for the main cue, allowing automark to do its work.  The setup cue cannot rely on the stage levels being controlled by the previous cue in the list or whether the current list has control at all..therefore the values stored (green zeros,white zero,or tracked out, in this case) which are relative to the previous cue in the list may not produce the desired effect.
2. In some version 1.4.x the white (autoblock) channels no longer have effect on playback levels (they don't assert).  This is ok because I can apply the assert flag to the intensity parameter on the mover.  The problem is you can't apply the assert flag to moving (green zeros).  Why would I want to?  Because you can change a green value to a white value without knowing simply by editing some previous cue, and now you need the assert flag that you wanted to put on earlier.
So, at this point I am getting the desired effect if I have a look onstage in a second cuelist (let's say a generic MC cue).  I hit go on my main cuelist and only the green/asserted channels fade out, automark fires, I hit go again on my next cue (Note: I have the assert flag set (A) and all channels are controlled in this list), and perfection results.  Well, almost. I realize at this writing that the global A flag may cause fly-ways and color changing on fade outs.  I could just assert the intensity value, but the better idea is to avoid non-conventionals in my MC cue.
So what if I accidentally went to my setup cue too early (nervousness, bouncy go button), and now I have my MC cue in control and I need to refire my setup cue.  If I reload the setup cue and hit go (see problem #1), bye-bye MC cue. I try ASSERT CUE <setup cue #>, same result as GOTO.  How about setting the tracking channel info I don't need to NULL.  Using ASSERT CUE <setup cue#> this time has the desired effect of fading the movers I need in the main cue and nothing else.
Bullet proof solution? Well how about those operators that loath...fear...don't get.. second cue lists.   If I  link to the setup cue (complete with null values) to alter the playback order, what happens then?  This brings up problem #....
3.  The quirky interpretation of null values by the console.  If you have nulls in your cues the console behaves as follows:
-Go in sequence...null treated as tracking.  Okay, so far.
-GOTO CUE <cue with nulls>...null treated as OUT , not like GO in sequence (huh?)
-Link to <cue with nulls>...same as GOTO <cue with nulls> I was hoping to use null as a workaround for stateful jumps. I mean null means DO NOTHING right?
-ASSERT CUE <cue with nulls>...null channel left alone.  This is what I (or anybody) would expect to happen.
Why don't I just go to black between acts to cover the ugliness?  Well, we only do live (fund raiser) recitals one or two days a year, with little rehearsal, on a thrust stage no less.  Having a B-lister fall off the deck while blacked out does me no good.
Another option is to move the conventionals to the setup cue to cover waiting for the movers to mark.  This means all act changes happen in two separate cues, and no sneaking the movers out early.
I could create inhibits for all the problems fixtures..I'm sure there are many suggestions for manual solutions.  I think that we sometimes forget that there is a powerful computing system underneath the keyboard  that should be able to handle these situations that have be around since the first scrollers were made.
[edited by: 33boardop at 1:12 AM (GMT -6) on Fri, Jun 19 2009]
  • Hi Richard,
    Absolutely love a good debate.  Thanks for entering it.
    Totally agree the scenario above yeilds very similar results, and I can appreciate that different things work for different people.  I would counter a couple points -
    1) Your assumption that I'm an 02 programmer is a little premature - I never found the Hog to be limited to a single stack :-)  I do however find it limited in workflow management tools for large scale shows which the EOS handles extremely well.  Also - I absolutely love true spread sheet effects for music - so I'm ETC all the way - Hoorah.
    2) Q's 20-30 have 1000 available Q's in between them.  I use a highly specific numbering system and single stack or not would encourage anyone to do so as well.   Q 22.05 is almost always going to be the 1st chorus for the second Artist running a ".5" style effect - So there's never any guessing - the song numbers itself, I just choose what parts to use.  Record next just encourages people to pay less attention to the numbering which has inherent risks.
    3) If you really do have 20+ cuelists you can never really get rid of that crib sheet in Live.  You still need to pick out a cuelist number sometime and the Blind Cuelist Display isn't very user freindly.  Even in 1.5 after 9 lists you got to pick up the mouse to scroll down to see the numbers/labels - and then to edit that list in blind you gotta type in the list number in order to populate the cuelist.
    Since it's a theatrical console at heart the EOS handles long primary lists very very well - I can next through my cues from live or blind. It's all right there to be edited already.
    4) Since I run a lot of other faders I wouldn't want to have a global block/assert on one of the little go buttons - it  just invites disaster.
    5) I dont particularly like running Q's from the execute line (there's a bit of a lag time and order in which things are fired can have implications to LTP objects)
    I find Goto Q in a live live show leads to problems.  Even with the O2 keys on the Eos - typing mistakes are just a part of life.  The moment you hit enter on a goto command, your done.   [Blind] [Link] [#] [Enter] has a few more key strokes, but the link auto-posts (if the link line was previously blank), and I get a chance to look at it a couple times before I hit Go.
    6) With Multi Stack I'm much less likely to be able to see what's coming up, which can be a real problem.  These are often times 1 or 2  day shows, rehearsed out of order with no dress.
    7) With multi stack at some point you need to stitch it together, by whatever method.   No matter how you look at it - it's just something else to do.
    8) As before - mark always requires a reference so if you Assert other lists you always have to manually make sure your clean.
    9) From top to bottom this desk has been designed and advised by pure traditional theatre folk.  I spend a lot of time swimming upstream with this console - for all the reasons above I find this issue not worth fighting.
    Again - I totally appreciate the debate.  No one ever really discusses work flow related issues and I think it's a very healthy discussion to have.
    If you can get a rock solid handle on the cue numbering, the benefits of a single main Q list on this console can be  very real.  It's less stuff to manage, fewer screens to look at,  stitches itself together automatically, has superior display attributes during playback and your mistakes are less likely to be catastrophic because your asserting less out of context.
  • 1) You got me there!
    2) I'm quite used to building a framework that other people have to fit their parts of the show into - so I try to make it hard for them to mess it up. As long as they stick inside their designated cuelist(s), they won't break the show. As integrator, I just have to check the top-and-tail of the cuelist.
    3) Yes, you'll probably need a cribsheet regardless, but it's much easier to rebuild that cribsheet if it's all in one list on the console.
    4) Remember that you can link the last cue of Cuelist 1 to the first of Cuelist 2 instead of putting them on multiple physical or virtual faders. I don't think you could do that on Hogs (been a long time since I used one). So there's no need to have the extra cuelists on faders if you don't want to.
    5) Yup, you're right there. Goto Cue is an 'emergency' thing - which is why i like them to be as obvious as possible. In this kind of show, you're doing it because the running order changed unexpectedly - otherwise you're linking one act to another (either cuelist to cuelist or cue to cue).
    6-8) Hmm - I tend to think in terms of single acts that I'm stitch together, rather than a whole show broken into parts. Many of the Variety shows I've done didn't have a running order, or the running order changed every night with acts joining and leaving, and many of the other shows of this general type have been
    That's probably some of the reasons why I approach this from the other angle.
    9) Yes, Eos and Ion were designed from the ground up to be excellent theatre and opera consoles - this kind of 'live', seat-of-the-pants stuff is more what Congo was aimed at. The core strengths of the two families are quite different, while they do almost fully overlap in capabilites.
    Quote:
    We should be able to set a cue level flag to indicate our intentions to the console to not allow our movers to move for this particular cue. This would allow the console to use delays, edit confirmations etc to enforce our intentions.
    I don't understand. You appear to be saying "I want to tag a cue to say that movers must not move. Thus when I goto it, it does not actually play back but leaves the movers pointing in a random direction and in a random colour". Is that right, or do you mean "The console refuses to let me Goto that cue"?
    What do you mean? Can you give examples?
    To be honest, It really feels like you're after a "Do What I Mean" function, which sadly isn't going to happen. It is just a computer after all.
    [edited by: Richard at 1:59 PM (GMT -6) on Mon, Jun 29 2009]
  • Richard;
    I don't consider GOTO CUE a standard playback function, therefore it would be exempt.
    I never used the word "random".  The lamps are moving/ fading to known values, but it doesn;t mean those moves have to occur simultaneously.  I merely proposed a way to invoke a stricker "defined"  playback ruleset, that the programmer can option on or off on a per cue basis.  This ruleset would only apply to "GO " actions. More on this after 1.5 appears on the downloads page.
  • 33boardop said:
    ...the least they could do is assign macro numbers to the unused keys on the keyboard, so we can at least get our money's worth out of them.
    I believe they have....I haven't got the console in front of me, but I think they're numbers 801+ (am sure someone will correct me if I'm wrong - and this might be a 1.5 thing)
  • As of version 1.4.5 macros 801 thru 803 are mapped to the three unused buttons on the left pillar above the PARAMS button.  I refer to three blank ones on the desk (four if you include "FAN", 5 if you include "PATH").  You can verify this by activating the "Virtual KeyBoard".
  • 33boardop.... we have plans for those three blank keys on Eos - that's the reason we haven't mapped macro numbers to them.  Our concern was that users would get used to having their macros in those locations --- and then we'd take them away.
    I am interested to hear your thoughts on playback intent.  I'm with Richard in being a bit confused about what you mean.  Examples would be great.
    thanks all.  Interesting discussion.
    a
  • When you guys hammer this out, would you please address this hopefully pertinent question.  Is it, or will it be the intention for Automark to work for out of sequence cues, linked and loaded?  Whereas if a fixture's intensity is out and a load command is executed for an out of sequence cue, will the fixture re-mark for the new next cue?
  • Yep, we just talked about that.  We will be able to automark for linked cues.  We will also automark cues loaded into pending when they are loaded - or when possible if the lights in question are fading out in the currently active cue.   In 1.5, we've added an automark feature for broken referenced marks.  So, if you are using referenced marks, on a linked or non-sequential loaded cue, we will be able to use that feature to handle marking the lights.  Will put on the list.
    a
  • Anne,
    My intent was to have at least one user definable key close to the numeric keypad, to deal with various issues (broken keys, repeated motion problems). One LD you know like to use UNDO at lot. “Ten at full…UNDO, Eleven at full.. UNDO” etc. The problem is this tends to leave the UNDO list popup on the RVI, unless I remember to hit clear. A macro like UNDO ENTER CLEAR on a nearby button would be extremely handy. Of course, this brings up the issue of general keyboard remapping, like the RVI and RPU units.
    With Auto mark, I realize the problems a multi cue list board presents when dealing with which cue list will mark and which will not, and the console not knowing which GO button will be pressed next. It’s these unknown transitions where auto mark falls short. Where auto mark works prior to GO on the marked cue, once GO is pressed the effort is abandoned. What is needed here is a feature that alters the cue timing on a per channel basis after GO is pressed. Since the console cannot know our intent automatically, we need a new flag in the cue list to give authorization to the console to alter our programmed timing, as needed, to avoid live moves.
    Since screen real estate is precious, this column could also be used to indicate the “live move status” of each cue. You already have some of this functionality now. When I bring a light up and set it to a new position, auto mark will place an “M” in the previous cue flag column. Therefore, whenever I see an “M”, I know that I have a light fading up from zero, and that auto mark will deal with it.
    But what about lights fading out and moving? , or lights I forgot to reference mark ,or lights moving and not fading at all. All these conditions can be detected during editing, the same way auto marks are detected, and an appropriate symbol displayed.
    I have more thoughts on this topic but plan to wait until 1.5.x is released, before I chime in again.
    Currently we’re using 1.4.2. I had said the worst thing that could happen was we would have no crashes during the current season, and no crashed have occurred in front of an audience, so in order to justify the risks associated with upgrading, we need to see some major programming advances.
  • Interesting.  Have you had any keys break on the desk?  Just curious.  Regarding the CIA on the RVI/RPU, 1.4.5 does have much better handling of this.  We are also adding a lock feature (on or off) to keep that from distracting the designer.
    I'm still not quite clear on what you mean in the second paragraph.  Do you intend to alter the programmed timing on the fly just for the marked lights?   You are specifically talking about stepping on a mark by not letting it finish before pressing go?  Just trying to make sure we are completely on the same page here.  By avoiding live moves - again, is it just the situation where you are stepping on a mark, or prohibiting ANY live moves?
    We have added in 1.5 a "dark move" indicator in the mark field.  We've discussed adding a live move flag as well.  Were we do to that, though, we'd need to add - as you suggest - a separate field for this.... as that mark field is getting a bit crowded, especially when using referenced marks.  And I take it you are interested in a different mark indicator for the lights already dark that can mark right away, and those that are fading to zero and then marking?
    Another change we've made to mark (referenced) in 1.5 is color indication.  A marked light is now displayed in green, with a green "M" in superscript. The only time the NP values are displayed in blue when the lights are moving and are not marked.  This should help identify what lights are marked and which aren't more quickly than looking for the "M".   You can also query for marked lights.   Also, lights that are still in motion via a mark instruction are displayed in light green until the mark is complete.
    I think your plan to stay on 1.4.2 right now is probably for the best.  Were 1.5 to be further in the future, another suggestion would be in the offering.
    So, you've given me a clue, as I've been trying to figure out who you are.  :-)    Do I know you?  Are you at LAO?  (Or you could eliminate the suspense and just let me know!).
    a
    [edited by: Anne Valentino at 5:26 PM (GMT -6) on Tue, Jul 7 2009]
  • a,
    No broken keys yet, some stubborn ones though. The main issue is ergonomics. The longer your forearm, the farther away you must sit to use the numeric keypad, making the top of the CIA quite a reach. I compensate by using a pencil in my right hand, and two finger typing to maintain a clear view of the keys.
    As to the other point, I’m talking about where marking has missed the boat altogether. When you press GO and the console begins constructing the transition, if it finds itself (for whatever reason ) building a fade to or from zero with an FCB move as well, it should look at our new No Live Move flag attached to the cue and apply a delay to either intensity or FCB moves . This is beyond the scope of auto mark since it requires alteration of the programmed timing, where auto mark works around the timing.
    [edited by: 33boardop at 10:53 PM (GMT -6) on Tue, Jul 7 2009]
  • Anne,
    It seems as if a great way to begin to address the haziness with regard to Block, Assert, and AllFade is to correct the manual.  Perhaps I'm part of a dying breed of manual-readers, but I found the information in this forum in sharp contrast to what i found in the PDF manual (which i refer to at the tech table if i need a quick reference).  Page 147 of the Ion Manual v1.4.B: "Assert is only needed when working with multiple cue lists."  It sounds from this post and this post that this statement is not only misleading but actually false.  In fact, based on those linked posts, it sounds as if AllFade, rather than Assert, is the feature to use when attempting to control channel behavior when running multiple cuelists, correct?  If that's true, the manual should certainly reflect that distinction.  Richard's simple clarification from this thread almost certainly belongs in a prominent place within the manual, if it is not there already:
    Blocking is a Recording/Updating function - it defines how updates will track (or not) through the cuelist.
    Asserting is a Playback function - it defines how the cues interact with each other.
    Just to clarify once and for all, an Obsession "Block" would translate to an EOS/ION "Block" AND "Assert", correct?  EOS/ION has separated the Recording and Playback functions into 2 flags that used to be combined into a single Block command in Obsession-speak, right?
    Obviously, this is an excellent and powerful feature and offers a great many benefits over Obsession Recording and Playback.  It's great to finally understand how and why these features have been added so that i may be better equipped to explain how these features work to newcomers to EOS/ION who have been, up until this point, depending upon Block to do the same thing in EOS/ION as it did in Obsession.
  • I second cfaber's assertion that the role of block, allfade, and assert is unclear in the manual. I have been trying to wrap my head around the role of these three flags, but I can't see to understand exactly what each of them does. Maybe a future video from you guys could clear this up. Hopefully, we're not the only two people who don't completely understand the role of these features.
    [edited by: ajblanck at 9:18 PM (GMT -6) on Wed, Jul 15 2009]
  • Actually, these features are targeted for a "bobblehead" video in the future.  Easily understood when you show them, but the more they are described, the more complex they seem.
    It appears that block and assert have been fully covered in previous posts.... if anyone still is unclear about these, please feel free to ask.
    Allfade.  Allfade is a quick clean up command. When an Allfade flag is attached to a cue, it essentially issues the command "if you, channel, are not getting your intensity instruction from THIS cue, you should fade out now, using the downfade time of the cue issuing the allfade instruction."  Submaster contributions are withheld.
    Does that help?
    a
  • Excellent, I think that the instructional videos are a good idea. I have seen the one on lighting control philosophies, and it was helpful. Addressing some common issues that people have with the eos line of consoles would be a good subject for further videos.
    Although the subjects of block and assert have been covered in the forum, the manual still seems confusing. The most misleading statement is found on page 147. There, the manual says that Assert is only needed when working on multiple cue lists.
