Astera Titan Tubes Pixel Mode Incorrect in fixture library 3.0.1.31
Hi All,
Have just come across a large issue when trying to patch Astera Titan Tube’s in Mode 111 d cct gm cro rgb 16 pix in Fixture Library v 3.0.1.31 they patch as 64 cells when they are 16 cells. I have also checked and downloaded the latest fixture library 3.0.1.39 from the FTP server and that still contains the same issue.
The work around for now is to merge a previously correct titan tube 16 pixel mode in an older library version and then use that version of the fixture which responds correctly.
There are also issues with the 1 Pixel, 4 Pixel, 8 Pixel as well as the 16 Pixel. See attached screenshots & photos of the 8 pixel mode.
This needs to be corrected before the next version of software rolls out due to how often they are used in the TV & Film industry alone. I shall also make a post in the forums regarding this issue and the work around for now.
