I have a room full of conventional fixtures.
How do I find conventional fixtures in the patch library? All that I see are automated fixtures.
Thankx
sfb
Thankx
sfb
There are some conventional types in the Generic manufacturer, like Fresnel or ParCan. I usually just leave them as regular Dimmers because currently the only thing that changes are the models of the fixture. Since I use Augment3d to look at the stage rather than my rig it's not worth the extra work.
So, No is the answer to conventional fixtures in Augmented3d?
I think you mis-read uelis post a bit.
Here again the main answer:
Is there anything that you are missing, or like to see?
Is it only one generic ParCan, and one generic Fresnel? Are there others? 80% of my facility is conventional instruments. I would like my students to be able to see the difference between an ERS, and a Scoop-light in Augmented3d. Maybe i'm asking the wrong question. Can I create or import custom shapes of conventional fixtures? Thanks.
look at the fixture library in the Generic manufacturer. the fixture type with the 3D symbol have a model associated with them.
you can't import models for fixtures.
As of Eos 3.1.5, the following generic conventional 3D models are available:
Under Generic:
Under Practicals:
There are also Sphere and Washlight 3D models that can be applied manually:
