Auto blocks . . .
Unfortunately, I don't have a lot of detail at this time, but one of my clients has been having a world of grief with the auto-block functionality on their ION.  Sometimes, the auto-block will seem correct, and correctly show that a prior edit is being prevented from tracking through a following cue, but other times, it will cause the entire cue stack to basically lockup.  You can hit Go/Back, and see the cues supposedly run on screen, but what is output never changes.  Sometimes, a quick run forward through the stack past the block and then backing up over it will restore the console to normal operation, and other times, they need to reenter the cue with the block to get rid of the block. I can see an auto-block holding single channels (and indeed, that is all that is seen on the display) but this is holding entire cues, despite only single channel edits . . .
Frankly, auto-block seems like it should be a optional feature - good programming practice and attentiveness would tend to indicate that it is not necessary for all users.  Having said that, a short term solution to the problem would be to be able to simply turn the feature off, and deal with tracking changes manually.
Otherwise, has anyone seen any behaviour of this type?  I think we first noticed it on 1.8.0 (maybe 1.7 . . ) and it is still present in 1.8.2 . . . I will try to see if I can find a scenario to reliably duplicate what they have been seeing, but to date, it has happened primarily when I have not been on site . . .
- Tim
  • Ok... while we look at this, can you tell me why you store a cue with all channels at zero?  (cue 1).  Purpose?  Not there is anything wrong with it, but I'm interested to know why.  Since full blocks take care of any channel additions downstream...
    [edited by: Anne Valentino at 4:41 PM (GMT -6) on Wed, May 12 2010]
  • The first time we used muliple cue lists, there seemed to be an issue with newly created channels updating and autoplaying when first applied.  We decided the first cue in each cuelist should have a hard value for channels it intends to control so as to eliminate ambiguity, so our main cuelist usually starts with a cue 0.5 with hard zeros and all NPs in preset 1 as I don't like plus signs on the channel summary page.
    I observe with 1.9 a new unowned channel will want to update into the last cue played back.
    [edited by: 33boardop at 5:14 PM (GMT -6) on Wed, May 12 2010]
  • Yes. in 1.9, unowned channels update to the selected cue list.
    "The question to ask the software engineers is if a hard move to zero (green) in a Full Blocked Cue becomes redundant (autoblock), do they bother to erase it?  My observation is that autoblocks are only erased when the block flag is toggled, or when @ <enter> 'd by the user." --
    If you have a cue with a channel moved to zero (green) and the cue is blocked - and you match that move in an earlier cue, the move to zero becomes blocked.  I don't know what you mean "bother to erase it."
    Yes, blocks and autoblocks are only lifted by toggling the block flag or at entering the channel.    Blocks and autoblocks are handled exactly the same way.  The only difference between them is that you asked for the block and the system applies the autoblock.  Again, the channel in this instance is not autoblocked, it is blocked because the cue has a block flag.
    I only keep bringing this point up because when we add the autoblock clear utility, it is important to understand which blocks will be removed and which won't.  If it doesn't have an underscore... it isn't autoblocked.
    There is something pooched in the query cue command ... (sorry, I was trying the query at a specific level earlier).... working through it now.
    a
  • By "erase it" I mean't the actual move to zero".  When I "@< Enter>"  channel 1 in blind cue 2 the hidden move is erased, altering the query result. This tells me there was discreet data as well as the global block flag being applied.
    You will have to fix the usage report as well since the hidden moves show up there also.
    When you say "automatically by the system", it seems to me that block channels are  natural to a tracking board, all channels that have a move are by definition also  "blocked", and all blocks are requested, one way or another, by the user.  You can call a redundant move a fancy name like "autoblock" for the sales department, but the system didn't really have to do anything to creat it.
    The fact that when a move becomes redundant, it loses its affect on playback, is where EOS deviates from other consoles.
    It is clearly evident that when I edit a cue, EOS processes the entire cue list, looking for levels to declare "autoblocked", and filling the PSD with "b" s.  If a new "autoblock" is found in a cue that is already a "B" cue, what happens then?  Is the discreet data removed? I think not .... at this time.
  • As I have mentioned, there is an issue with querying cues.  It is related to what it means to be in the cue.  So, for the moment, it would be useful if we could leave the query discussion out of this.  Yes, there is an issue.  And yes, we will fix it.
    Blocks are not move instructions, they are editing tools.  Asserts are move instructions.  There has been quite a bit of dialogue on these forums about this.   And yes, we do differ from other tracking consoles in this.
    Yes, when you edit a cue, Eos processes the cue list to see if autoblocks are needed.  It also processes the cue list to see if the change should result in a track or a move.    I have said this before, and will say it one more time.  If a cue is blocked, any move instruction that is matched in level in an earlier cue will become blocked.  It is not an autoblock.  It it caused by the fact that the cue has a block flag.  Discrete data is not removed.
    This discussion could go on for years with no satisfying results on either end.  I would suggest that you contact either David Hilton or Lowell Olcott in our LA office..  Again, leaving query out of it, please tell them what your issue is.  Please show it to them.  They will interpret and let me know if we have an actual problem.
     look forward to hearing back from David or Lowell.
    thanks much,
    a
