Making a pile on cue
Hi, we are trying to work out how to create a pile on cue, so that we can see in one cue what in the show has been used and what hasn't, (so the display would have all the channels and the highest level they were in the show) if we look in blind at 'show channels' you may have recorded something with a vale of 0 so I'm not sure this would create what we want!
Any ideas?
  • My bad forgot to type that bit! ...cheers for the spot David!
  • Hi...
    At the risk of it sounding like I'm making a blatant self-plug, if you're doing this kind of 'data mining' on your showfiles a lot, you might want to take a look at FocusTrack: http://www.focustrack.co.uk.
    Once it reads in the data exported from your Eos showfile, one of the things it will tell you straight away is channels never used in the show - they appear in red in the channel listing. It can do much more than that, of course - show you palettes/presets used (ie. which gobos or colours have actually been used in the show - ie. set to that palette with the light on), and list all of the focuses used in the show.
    You can try a demo version for free to see if it gives you the kind of information that might be useful to you.
    Blatant plug over.
    Rob.
    [edited by: RobHalliday at 10:08 PM (GMT -6) on Tue, May 31 2011]
