ION multiple cue lists on faders
This is a little hard to explain properly.  I have multiple cue lists, each one stored on individual faders on my wings (40 at this point).  Each fader is set as imaster.  Some contain only LED drape cues and some contain movers with NO drapes.  (I've isolated the two for seperate control)
When I first start out and tap the bottom bump button to set the cue the scene actually lights up.  I then raise the fader to full, grabbing the intensity, then bring it to zero.  I then tap the top bump to release the cue.  I have to do this for every fader/cue list. Once I do that and I hit the bottom bump button a second time or any time after that the scene sets but no intensity.  At that point the intensity is then conrolled by the fader.
I'm pretty sure it happens each time I shut down and back up again and I am definately sure it happens every time a new cue list is recorded and saved to a fader
Any thoughts and do you need the logs?
