Selecting Masters request
When on the Master view there are times often when you want to just change the selection of Masters.
If you have several masters up and selected  it is quite long winded to  bring  those down and then select the one you want instead and bring it to a level
might it ever be possible when in the master view to be able use something like [rem dim]  [master]
... Or have I forgotten a trick
