Guide to triggering Eos via OSC from Qlab
Since I couldn't find a simple answer to this I've updated the Qlab wiki with details of how to control Eos over OSC from Qlab, to keep things simple I avoided needing to use OSCrouter, but this seems to work quite happily
Wiki is at https://figure53.hostedwiki.co/pages/QLab%203%20Tips%20and%20Tricks I have also pasted it below for reference.
Controlling ETC ION with Qlab 3 & 4 via OSC
Note: Requires QLab version 3.0.8 or later and a minimum ETC Eos Family software of 2.3.1.
On the console:
In the shell's network tab enable "UDP Strings & OSC"
Press [Displays] and expand {Setup} and then double click on Show Settings
Under the Show Control section, ensure these settings:
String RX: Enabled
String RX Port: 0
OSC RX Port Number: 9000
Note: Make sure your QLab machine and console are on the same network (and subnet) and can communicate before continuing (try pinging the console from the Qlab machine).
Within Qlab:
Head to settings > OSC NOT OSC CONTROL If using Qlab 4 then head to settings > Network
Set up a patch with the IP address of the console (find this from the about view on your console) and port 9000.
Create an OSC cue (on Qlab 4 now called "Network Cue"
Select the Destination as the patch you create above
Set the Message Type to "Custom OSC message" (Qlab 4 simply "OSC message" with "No Fade")
Set the message to:
"/eos/cue/XX/YY/fire"
Where XX is the cue list (normally 1) and YY is the cue, you can omit the cue list if you are using a single cue list on eos
Try hitting "Send message" to see if this works!
I have a hope that at some point figure 53 might integrate the eos OSC language directly into Qlab, however for now this appears to work fine!
NOTE - I have just updated this to show that the OSC RX and STRING RX ports must not be the same!
NOTE2 - Have changed the port as 3032 is the TCP port so I was silly.. Also added Qlab 4 info
Updated for changes
[edited by: richardWilliamson at 11:35 AM (GMT -5) on Thu, Oct 19 2017]
