Hello,
I'm working on file where I take notes from a midi file, use qlab to convert it to MSC and then send it trigger macros on the ION (bump subs mostly, but also run an effect and turn on a light and turn it on with a seperate macro). It seems however that I can't trigger 2 macros simultaneously. Is this just a limitation of the ion or is there a way I could work around this?
cheers
j
