Bug: Marking doesn't work across links
From the Ion manual:
When firing a cue that has a linked cue, the cue will mark like the linked cue is the next cue.The marks will fade using the active cue’s timing.
AutoMark: enabled
1 @ full, pan and tilt @ 0, record Q1
1 @ 0, record Q2
1 @ full, pan and tilt max, record Q3
An automark is generated for Q3
1: pan and tilt min, record Q4
Cue 2 Link 4
The "M" flag is in the PSD for Q2 but the channel doesn't mark. Q2 links to Q4 but in the transition to Q4, the intensity and focus change happens simultaneously.
This also applies to referenced marks.
