This works in a blind magic sheet command-button:
Effect 1 Step 1 Thru 6 ♦
- 1 Thru 999 ♦
Group 2 ♦
How can I make it in live?
- 1 Thru 999 ♦
Group 2 ♦
Blind ♦
- Chan 1 Thru 999 ♦
Group 1.2 ♦
Now you can call this macro from live or blind but it still works only if you're in blind when *calling* the macro.
What works a little bit as expected is:
Macro 1
Effect Open_Effect_Blind ♦
- Chan 1 Thru 999 ♦
Group 1.1 ♦
Macro 2
- Chan 1 Thru 999 ♦
Group 1.2 ♦
Now both macros change effect channels but work only in forground (why not in background?), they exit in blind, one needs to manually press esc as you cant record esc into macro (why?)…
so you get this kind of working when doing
[Macro] [1]♦
(little pause) [Esc]
If you're to fast with pressing [Esc], you interrupt the macro, and I cant put this into a magic-sheet.
What it is supposed to do is doing this completely in the background without changing actual view so i can put it into a magic-sheet button.
I got it wrong in my last reply to this, checking my macros I spotted that in a nested macro I actually have
Live [Enter]
Magic_Sheet 1 [Enter] Clear_CmdLine [Enter]
Which puts it back on magic sheet 1 in live mode, where I had the button that ran my setup effects macro.
So if you just put
Blind Effect [Enter]
at the start of your macro and add
Live [Enter]
on the end of your macros you can fire them up from a magic sheet in live, the console switches to blind does your stuff and goes back into live back on the magic sheet where you came from.
Live [Enter]
So if you just put
Live [Enter]
