Shielded Sub Issue
So in v2.6.1, I'm trying to have a shielded sub to shutter my projector. (So I can control it with OSC). I ran into an issue where a shielded sub won't release to background but a regular priority sub will.
Here are some details:
Using a Christy Roadster, with a Beam (Form) "Proj Shutter" parameter. Closed is 1, Open is 0. Default is 0.
Wrote Sub 1000 with Christy Channel "Proj Shutter" parameter at 1.
Made Sub 1000:
-Mode: Additive
-Master: Proportional
-HTP (doesn't matter)
-Priority: P4
-Stomp: Release
-Unmark 0: Off
-Exclude: Record + GM
When I type into command line [Sub] 1000 @ [Full] [Enter] the projector shutters as expected.
[Sub] 1000 @ [0] [Enter] - The projector releases back to background state, and un-shutters.
THEN, in sub 1000, I change Priority to Shielded.
[Sub] 1000 @ [0] [Enter] - The projector keeps the value from when it was at full and does not release into the background state.
The fader is reading as 0, but the "Proj Shutter" parameter is at 1 in yellow.
I tried to change (Unmark 0 ) to ON to no result.
So is this a bug? Should it still release to background state in shielded mode, or am I missing something?
