Had several slots in Sensor3 racks reporting over temp errors right after system was powered up. CPU temp was 72. Noticed that first slot with error had a R20AF module in it. Same in 2nd rack with problem. Swapped out the questionable relays for units on the shelf and haven't seen any more errors. Is this a known problem or is there something else I should be looking at?
