Trying to control about 50 Chauvet Epix Strips via the EPIX DRIVE 642 from dual sources - EOS and ENTTEC ELM LED Mapper. In theory this should be simple by just putting the ELM and the EOS on the same network at the same priority. I want HTP behavior for any given address based on which device, EOS or ELM, is talking louder so to speak.
Problem is the ELM is sending hard "0" data and the EPIX Drive seems to be interpreting the data LTP. Whenever EOS talks to the strips and ELM is not, they flicker between the EOS data and the hard "0" being sent by ELM.
Anyone have a clue how to get this to work HTP?
David Weiner
