I want to use the 911 - Incandescent Dim Curve on LED fixtures, but I have found at least on more basic LEDs that don't have an intensity parameter (i.e. CB12s) it makes colour mixing interesting because it applies the curve to the colour parameters, since the intensity is a virtual channel.
My question is if a fixture has an intensity parameter will assigning the curve to the fixture only effect the Intensity parameter or will it apply other parameters? Am I correct in thinking the anomaly with more basic LEDs is because the intensity is a virtual parameter?
