Hello,
How do I export all show files and magic sheets from my ION Console to the Software on my Computer?
Hello,
Magic sheets are stored in the show files, not as separate files.
Exit the main program to the shell (File> Exit, not File > Power off Console), then click on the Settings button in the shell.
Then click on the Maintenance button, which opens a window with a couple of options:
Put a USB drive in the Ion.
Exit to the shell.
Click Settings, then Maintenance, then File Manager.
Open the USB drive folder in the right pane.
Select all files under D:\ShowArchive (you can use shift&left click)
Click "Copy>"
It takes a couple seconds for the files to show up in the right pane.
Put the USB drive in your computer and use Explorer to drag your show files into Documents>ETC>Eos>ShowArchive (This may be different on a Mac)
Magic sheets are part of the show file so they are automatically part of the export.
