Feature Request: Next Available (used for recording)
Hi all,
I would find it really useful if there was a way to record to the next available (or next vacant) target which is determined by the desk automatically. This would be most useful in macros that record stuff like cues, pallets, etc.
Here's a usage example: When busking, like many I like to record looks as I go. I have a macros to record to different targets quickly so I can revisit stuff later. Using record next isn't too helpful in a macro as it's likely that I'm not sitting in the last cue and so it's not usable. If this was an available function, then I'd never need to worry about the macro attempting to overwrite a target and a "please confirm" prompt to display when trying to work on the fly.
It would also be handy if you're working somewhere else in the cuelist, you want to save a new cue to the end of the stack but can't remember whet the last cue is... [record] [next] {available}. Bam. I know there's other ways to find out this info, but that seems fast, you don't even need to look.
Would also be good if you could define in show settings what the minimum number would be. Even better if you can define a number for each target.
Cheers!!
