Hello,
i worked with the x4 Bar20 and find it a bit confusing that the functions are called with different names.
refer to: Normal Mode here, 'cause haven't used an other
Is it possible to rename them as they are in the manual?
Speaking of:
Patter select, Pattern Movemant, Pixel select
for now they are called 'FX macros' or 'Mode'
And i noticed that there is a FX Macro3+Rate and no Rate for FXMacro wich should be FXMacro1
Can't find FXMacro3 in the manual
thilda
