I have a button with a macro that shuts down Eos.
I would like it to also to then turn off the PC after Eos exits.
Any thoughts on how to accomplish?
Run eos.exe in a batch file that runs the Windows shutdown command upon exit.
Alternatively, investigate Windows single-app kiosk mode.
I had forgotten all about batch files in these days of windows 10, great idea, thanks!
I looked at the kiosk, but it needs windows 10 pro/enterprise/education.
Try this:
C:\Programme\ETC\eos.exe
shutdown -s -t 30
If you have install EOS at drice C.
Create it with Notepad and store it as ***.bat
So if you end EOS Nomad the PC shutdown.
Normal the count behind the "t" is the time the PC will wait for shutdown after you haven end EOS Nomad
Have you used windows kiosk mode to run Eos?
I can't get it to work because EOS wasn't installed from the app store, and I'm having problems getting the "Application User Model ID" AMUID needed to do it via powershell.
