iRFR command line
Hello all,
I have set up a new network using an Airport Extreme and am having issues with the iRFR. I can successfully connect to the network and the console, but nothing posts to the command line when I hit buttons. I can still call up channels and do a channel check, but I don't see anything in the command line. I have restarted the app and my phone, and the problem has persisted. My boss is having the same issue
Parents
  • You are connecting as a different user.  Which version of iRFR are you using?  On the paid newer version you can select what user you are but I believe it defaults to "auto".  If you want to see the actions on the console command line you need to use "console" in the iRFR config.
Reply Children
No Data
